Basic LES Qestion
Old   October 24, 2002, 10:02
Default Basic LES Qestion
Dave
HI everyone, I have a small understanding of LES simulations and have a very basic question. What happens if you use LES with a coarse mesh. In an ideal world when using a Ke turbulence model you would want to model down to y+ values of approx 11 to 50. But often y+ values (at least ina comercial field) very rarely get down to these levels. So what would happen if LES were used at mesh sizes above the Kolmogarov length scales (assuming that it is correct to try and model down to that level?)? Dave
Old   October 24, 2002, 12:00
Default Re: Basic LES Qestion
Tim
The simple answer is the larger the cell you use the more important the Subgrid model becomes. In LES the scales above the filter size (related to your cell size) are directly simulated and the scales below the filter size are approximated by the subgrid model. When the filter size = the kolmogorov length scale you do not require a subgrid model (This is DNS). The use of a large cell also means that you do not resolve important phenomena at the wall. In general I would advise running a simulation on a coasre mesh to check if everything is o.k. If you do this you will get an idea of the accuracy. If you need to improve the accuracy put more cells in (or change the subgrid model - or both)
Good luck.
Tim.
Old   October 28, 2002, 04:43
Dave
Cheers Tim, that has cleared up a few questions, no doubt there will be more as we progress, Dave
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Basic LES question toyCFD Main CFD Forum 3 August 23, 2006 15:09
LES..Basic Question NIK Main CFD Forum 13 May 19, 2004 19:03
LES.. Basic Questions NIK Main CFD Forum 8 May 19, 2004 18:24
