January 14, 2003, 07:41 |
Graphical user interface
Hi, I have a written a fortran code using finite volume methods. I want to write the graphical user interface so that user do not have to go into program everytime he changes input values. How to write it any help please
January 14, 2003, 09:56 |
Re: Graphical user interface
I think the easiest tool might be Visual Basics if your code runs on PCs. |
January 14, 2003, 10:13 |
Come on one more programmming language to larn.Anyway I am in linux. Prasat
January 14, 2003, 19:42 |
What about Perl/Tk. I used it for the same purpose and it is easy to learn and platform independend.
January 14, 2003, 20:55 |
You may use the Visual Fortran.It's as convenient to use as Visual basic. Good luck.
January 15, 2003, 03:09 |
There are too many ways to skin this particular cat. Easiest way my be to use Borland Kylix (i.e. Delphi (or Pascal) that runs on Linux) to write a GUI that edits an input file.
January 15, 2003, 03:27 |
Hi maximus, give me some site about visual fortran. prasat
January 15, 2003, 06:19 |
Hi,Prasat:You can search it with Google.There are too many sites.The following are two of them:http://intel.forums.liveworld.com/. http://www.qtsoftware.de/dvf/ By the way,I have seen the textbook of Visual Fortran in bookstore,so maybe you can find one in the bookstore.
January 15, 2003, 10:29 |
#9 |
Java's JFC is pretty neat for building GUIs, etc. For look & feel, check out my attempt at learning Java: www.scs.gmu.edu/~nahmad/tekon2d/tekon2d.html
January 16, 2003, 02:57 |
#10 |
hai nashat, I just want to know whether I can run this linux or not.And any information how to start with.I already mentined that I have program in Fortran. Bye prasat
January 16, 2003, 08:39 |
#11 |
Hi Prasat, Java is platform independent - It will run on almost any platform. There are tons of tutorials and code examples on the web - Try search on JFC or Swing. You can download Java for Linux from java.sun.com.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
user interface | saghir | FLUENT | 0 | May 7, 2007 05:23 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
