The turbulent viscosity on the wall
Old   January 23, 2003, 11:07
Default The turbulent viscosity on the wall
maximus
Hi,I use the K-e model along with an one-equation model in the near wall region.How to evaluate the turbulent viscosity (Mut)on the wall?Is it equal zero?From the one equation model,the turbulent viscosity in the near wall region is evaluated as :Mut=Cu*sqrt(k)/Lu,where Cu is the constant for k-e model and Lu is the length scale. Should I get Mut from the above formulation ,or set it to zero?Which is reliable?Thanks a lot. maximus
Old   January 24, 2003, 02:49
Default Re: The turbulent viscosity on the wall
Fabian
The turbulent shear stress is tau_t=rho*u'*v' (1). In eddy viscosity models you assume tau_t=rho*mu_t*du/dy (2). From equation (1) you see that the turbulent shear stress is zero at walls. So take a guess which term in equation (2) has to be zero in order to follow this condition?
Old   January 24, 2003, 03:02
maximus
It must be mu_t to be the zero term.Thanks.
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Turbulent Viscosity - Floating Point Error Johnny B FLUENT 1 November 26, 2003 08:42
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 08:56
Turbulent viscosity Christian Holm Main CFD Forum 4 June 23, 2001 22:04
