A simple question about microchannel flow!
Old   January 27, 2003, 13:02
Default A simple question about microchannel flow!
Sally Yu
Dear sir:
I would like to simulate the compressible microchannel flow(1.2 micrometer heigh, 3000 micrometer long, gas constant=296.7, absolute viscosity=1.85e-5, ratio of specific heats=1.4, the working fluida are nitrogen). The outlet Knudsen number and outlet pressure are 0.055 and 100.8kpa, respectively(experimental data by Pong). The numerically result are compare with Numerical(Chen et. al and Dr. Raju) and experimental data(Pong et. al). But after several tests I found that the outlet Knudsen number seems not equal 0.055.
The outlet density can be solved by using eos: p=rho*R*Tout==>rho=1.082
so, kn=mu*sqrt(pi)/sqrt(2*R*Tout*rho^2)/H==>0.0585
I don't know what's the problem. Has anyone calculated this problem? Please help me. Thank you very much!!
Best regard
Sally Yu
Old   January 28, 2003, 13:11
Default Re: A simple question about microchannel flow!
Marc
Dear Sally,
if I am right, the Knudsen number is the length of the mean free path of a molecule. You did not measure it directly, right? All exprimental data will contain some error, maybe 5 % (if they are excellent).
0.0585/0.055 is 1.064, only 6 % difference. Why do you worry? Did I understand your problem correctly?
Greetings,
Marc
Old   January 28, 2003, 14:42
Sally Yu
Dear Dr. Marc:
Thank you so much for your reply. Actually, two engineers has calculated this case before. They clear said "outlet Knudsen" is equal to 0.055, and the numerical result seems very similar to each other. So, I'm worry about different outlet Knudsen number may cause large numerical error (such as pressure distribution and slip velocity). Am I using wrong equation for calculating outlet density? Please help me. Thank you very much!!
Best regard
Sally Yu
Old   January 29, 2003, 02:30
choi
I think that Kn=sqrt(pi)/sqrt(2*R*Tout*rho^2)*1/H.? It may be helpful to review the article "The fluid mechanics of microdevices-The freeman scholar lecture"-Journal of Fluid engineering, Vol. 121, pp. 5-33, 1999. The difference is due to the fact that a few thermodynamic properties you used is different from those of previous articles, I guess. These are empirical constants and therefore can have slightly different values corresponding to the referencing chart.
Old   January 29, 2003, 03:37
Sally Yu
Dear Dr. Choi:
Thank you for your help!! Sorry to disturb you again. Did you ever calculated this case (microchannel flow)? If I want to calculate wall slip velocity (u=Kn*du/dy). Which Knudsen number I should use(centerline Kn or not?)? Please help me!!
Best regard
Slly Yu
Old   January 29, 2003, 20:50
choi
Centerline Kn number is appropriate. If the flow is near equilibrium in the bulk flow region(slip flow), this value(Kn) is easily obtained. I'm not a PhD, now. The degree will be obtained February, 2003.
Regards.
H. Choi
Old   January 30, 2003, 02:03
Default Thank you for your help!!!
Sally Yu
Dear Choi:
Thank you for your kindness!!! Thanks!!
Best Regard
Sally Yu
a question about mass flow in multi-component flow frank CFX 0 May 12, 2008 07:38
A simple question. yaseer Main CFD Forum 0 March 12, 2007 13:32
Air Flow within a Wind Tunnel Question Paul Kleinmeulman FLUENT 3 January 12, 2005 19:09
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 04:58
