March 23, 2009, 10:58 |
Visualisation of results
Prakash Ayappan
Rep Power: 17 |
Hai Friends,
Presently I am doing a 2D-variable duct prblem. I have written codes in C and got the reults in text. Next I like to visualize the results in Paraview. But I dont know how to format the file to give as the input to the paraview. I checked a lot of trainning manuals for the formatting of input file. I startesd with VTK file extension and lot of hard work I didn't get any useful results. So I need your help to give some advice on the formatting of the input file. I want to see the velocity, pressure contour & stream traces. I have attached the problem & the results. Help Me. Thanks in advance. |
March 23, 2009, 14:19 |
Rep Power: 17 |
Your grid is a structured one, if not, from what elements it is made (triangles, rectangles ....).
Can you use other visualisation tools like Matlab or Tecplot ? Paul |
March 23, 2009, 14:56 |
Newton KF
Rep Power: 17 |
Have you tried some free libraries from the net???
What is wrong with your export code for VTK??? I have already worked with that, but today I'm using tecplot... it is not easier to implement but has valuable features that other programs don't have... If you need some help on your code, please post it in some public place to allow others to analyze it... I may help you if I can... |
March 23, 2009, 18:14 |
Rep Power: 17 |
Search the net for VTK file formats, and use the legacy text format, this seems to be straightforward to implement if you know a bit of C++.
I suggest you to use the STRUCTURED_POINTS format this will map exactly your domain if you use 3 rectangles. Let me know if you need further help, Paul |
March 23, 2009, 22:38 |
Prakash Ayappan
Rep Power: 17 |
I am using rectangular grids. Tried in MATLAB, but failed. I have no TECPLOT. Trial version of TECPLOT is not supporting my feature.
March 23, 2009, 22:41 |
#6 | |
Prakash Ayappan
Rep Power: 17 |
I have attached my problem defnition and results. |
March 23, 2009, 22:43 |
#7 | |
Prakash Ayappan
Rep Power: 17 |
Pls help in formatiing of my results into VTK format. |
March 26, 2009, 10:12 |
try visit
i like the data format of tecplot |
March 26, 2009, 12:28 |
#9 |
Prakash Ayappan
Rep Power: 17 |
I could not understand your words.
March 26, 2009, 14:47 |
#10 |
Newton KF
Rep Power: 17 |
Visit is a program for visualization of results from numerical analysis: https://wci.llnl.gov/codes/visit/
I think, it works with the vtk file format... |
March 26, 2009, 14:48 |
#11 |
Rep Power: 17 |
You can use any programming language for writing a simple formated text file ( aka VTK format), if I understand correctly you know C, this will help you.
March 26, 2009, 23:13 |
#12 |
Prakash Ayappan
Rep Power: 17 |
March 26, 2009, 23:15 |
#13 |
Prakash Ayappan
Rep Power: 17 |
March 26, 2009, 23:16 |
#14 | |
Prakash Ayappan
Rep Power: 17 |
March 27, 2009, 06:43 |
#15 | |
Rep Power: 17 |
The VTK file format is described on the NET, just search after VTK file format on google. If you know any programming language you will be able to simple re-write your results in this format. If you need specific help write me in private. |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
validation of CFD results | andy | FLUENT | 0 | June 13, 2007 13:55 |
Problems with repeating results | Lee | Siemens | 4 | May 26, 2006 03:39 |
CFX cylinder or sphere benchmark results | Mel | CFX | 1 | August 8, 2005 18:47 |
benchmark results | stefan | Siemens | 3 | September 10, 2001 09:48 |
