March 17, 2003, 17:13 |
Can CFD do this?
Can CFD simulate the refrigerant flow in a heat pump set up? The refrigerant flows through evaporator and condenser thus phase changes.
March 18, 2003, 03:18 |
Re: Can CFD do this?
1) In general I would say yes. 2) But I suggest it it is very hard to obtain good results for predictive purposes. 3) The flow is a two-pahse one with phase change. So you need a code which can handle this type of flow. A code with an Euler/Euler multiphase model plus a phase change model can handle such flows. 4) The problem is the interfacial shear which limits the maximum heat flux a heat pipe can transfer. At a certain heat flux level the momentum transfered from the gas phase to the liquid phase is high enough to hinder the liquid flowing from the condenser to the evaporator. And this operation point is very distinct. 5) In an Euler/Euler model momentum exchange is handled via equations which in general are empirical ones. You can choose between several ones which are valid for individual flow types. 6) That rises the problem of what equation to choose and the validity of it for your certain geometry and fluid. I suppose that there is little material in literature for it. You may search for the key word flooding. 7) A solution might be to adapt the empirical coefficients in the momentum exchange equation so that your simulation follows your experimental data. But I suppose if your coefficients fit for one geometry and fluid it will fail for a slightly different geometry. 8) Conclusion: In general yes, in particular no or with lots of difficult problems to solve.
March 18, 2003, 06:31 |
Helge,
Please give your comments on Heat Pump not heat Pipe. Thanks. |
March 18, 2003, 08:12 |
O.K. I misunderstood or did not read the first question carefully.
1) In general I think that you can simulate that flow 2) It only depends on the boiling and condensation models you have 3) May it is a good idea to not simulate the whole cycle in 3D but to split it into evaporator, condenser and piping. It is also possible to connect evaporator and condenser via boundary conditions to get rid of the piping which may not be very interesting 4) If you are not interested in flow details you may set up the whole cycle in a 1D model in which the functionality of every component is modeled |
March 18, 2003, 10:35 |
Helge...Can CFD-ACE do it?
Hi Thanks a lot for your response. Can CFD-ACE do it? Do we have the option of selecting various refrigerants in there?
March 19, 2003, 08:24 |
Re: Helge...Can CFD-ACE do it?
I do not know what CFD-ACE is capable of
Display Modes | |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 13:23 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 05:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 12:44 |
