April 7, 2003, 22:20 |
how to set the BC of the backstep?
dear all 3D,subsonic,compressible,the rate is 1.5 . the inflow bc : r,u,v,w are specified,P float. the outflow bc: only p is specifyed, and equal p(infinity) up and down : no-slip wall spanwise : period
Macomark scheme(1969) is used in my code. the velocity v is not zero near up-wall of inflow , and the value is about 0.25(non-dem) why? is it 'Ossen flow'? Because i can not find the DNS results of channel flow,i have to deal with my inflow bc like that pre-mentioned. the velocity u is sepecifyed the analytical solution of Poiseuille flow ,although the code is compressible(Mach number==0.2). would anyone give me some advices? thanks. |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
$FOAM_USER_APPBIN & LIBBIN variables not set | rassilon | OpenFOAM Installation | 2 | February 16, 2010 20:54 |
Install problem in linux | navaladi | OpenFOAM Installation | 11 | July 17, 2008 02:24 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Ibm java gcc | rrr | OpenFOAM Installation | 2 | December 30, 2005 04:18 |
