Mesh data to be read by Fortan code
Old   April 19, 2003, 14:31
Default Mesh data to be read by Fortan code
seckin
hi, I have created a mesh using Gambit and I want to write the vertex data into a file and let my Fortran code read from that file. I tried to export the mesh from Gambit in some formats but I couldn't figure out the writing style of Gambit. I want the file be in the following format: do j=1,jmax x(i,j), y(i,j), i=1,imax enddo but I guess Gambit writes differently than the above scheme..am I wrong? can anyone give me a clue on this? thanks,regards seckin
Old   April 19, 2003, 17:38
Default Re: Mesh data to be read by Fortan code
Jim Park
I hope you meant to write:
do j = 1, jmax
do i = 1, imax
read x(i,j), y(i,j)
end do
end do
Old   April 19, 2003, 19:19
seckin
yes that's correct.. thanks for correcting.. seckin
Old   April 19, 2003, 22:36
xueying
You can write a Fortran code to read the informations you want according to the mesh files you generated by skipping some not useful lines. I think it's not possible that the mesh file only have the position informations, otherwise the mesh file doesn't include enough informations.
Old   April 23, 2003, 10:53
Mike
Merhaba Seckin, Bence yapman gereken sey GAMBIT el kitabini bulup grid dosyalarini hangi formatta kaydetdiklerini anlamandir. Daha sonra belirtilen formata uygun sekilde gambit grid dosyasindan x,y datalarini okuyup istedigin formatta yazdirabilirsin. Onemli olan kesinlikle gambit el kitabinin verdigi formata bagli kalmandir.
Old   April 24, 2003, 22:58
Selina Tracy
Italian! Dose not look like German, French or Spanish. Might be Iraq's. -Selina
Old   May 13, 2003, 17:59
Yuan
I don't think Gambit data can be read into Fortran Code. I recommend Gridgen.
Old   December 15, 2020, 12:51
Bappi
mohammadbappiamin is on a distinguished road
Originally Posted by seckin
;24196
I have generated a 2D mesh using Gambit and now I need to read the mesh that is generated. Did you find or write any program in Fortran? Do you mind sharing it with me? I am really struggling with it and I would appreciate if you can please help me out.
Thanks
Bappi
mohammadbappiamin is offline   Reply With Quote
Old   December 7, 2022, 00:58
XIE JIN
JINXIE is on a distinguished road
Originally Posted by mohammadbappiamin View Post
Thanks
Bappi
Did you developed the code to do that? I am currently working on this as well, can you give me some advice? Thanks
Best, Jin
JINXIE is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
How to read mesh data from ANSYS mspilot FLUENT 3 August 21, 2003 06:00
