May 15, 2003, 14:10 |
A different view
Consider the "visuals" of the following:
1/ "Standard" wind tunnel wing c/w streamlines. - At low AoA the air is leaving the trailing edge at an angle of -say- 15 degrees below horizontal 2/ A helicopter rotor in the horizontal plane. - At low blade AoA the airflow is STRAIGHT DOWN So why the difference? In 1/ the air is moving over the stationary wing In 2/ the wing is "cutting" through the stationary air Why in "all" textbooks is option 1/ chosen? Maybe this was the "standard" and "only" option before CFD visuals. Why not use CFD to promote the visuals of option 2 which in my opinion is the more "truthful" option since in the end lift is the reaction force to air being "forced" vertically downward by the "wing". |
May 27, 2003, 15:11 |
Re: A different view
OP again.
Support for this "view" can be found in this excellent paper BUT no CFD support to produce option 2/ views. http://www.aa.washington.edu/faculty.../Lift_AAPT.pdf |
[General] Paraview User defined view | prapanj | ParaView | 3 | January 3, 2014 20:54 |
View particle trajectory in CFD View | xonix | Main CFD Forum | 1 | April 25, 2011 23:40 |
normal view and view with outline | Ivanjica | OpenFOAM Post-Processing | 0 | September 11, 2010 02:02 |
Fluent - View Factor for s2s radiation | Markus | FLUENT | 1 | October 16, 2005 01:33 |
view rotation in provis | Anna (aka new-user) | Siemens | 3 | November 19, 2004 08:45 |
