to find the exact solution of 1D Burges Equation
Old   May 11, 2003, 05:17
Default to find the exact solution of 1D Burges Equation
Tian Baolin
the Eq. u,t+u*u,x=0 u(x,0)=alpha+Pi*sin(Pi*x),-1<x<1
the analytic solution?
thanks!
Old   May 12, 2003, 04:33
Default Re: to find the exact solution of 1D Burges Equati
Tom
If you mean the inviscid burgers equation (u_t + uu_x =0) then the solution is, parametrically,
u = U(s) = alpha + pi.sin(pi.s),
x = s + t.U(s)
Old   May 12, 2003, 08:13
Tian Baolin
Dear Tom, Thanks a lot for your solution.Yeah,I just need the solution of inviscid burgers equation.I am sorry that I had given a poor expression of my issue. Your reply is of much help for me,but could you give me a detailed explaination for me. I can't understand meanings of 's'and 'U(s)'. Thanks Again!
Yours sincerely Tian Baolin
Old   May 13, 2003, 04:34
Tom
s is simply a parameter if you fix t and vary s you get the values of u and corresponding values x. Another way of looking at it is to think os s as a Langrangian marker for a fluid particle. If you fix s and vary time the value of u does not change and so is equal to it's initial value U(s) while it's position (x=s at t=0) has changed due to convection.
Hope this helps - you may want to look at the book
"Linear and Nonlinear Waves" by G.B. Whitham
which discusses the Burger equation in detail,
Tom.
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
Neumann Boundary Condition for Poisson Equation solution in Polar Coordinates prapanj Main CFD Forum 2 July 30, 2011 19:07
Exact solution of Buckley_Leveret equation mcaro Main CFD Forum 0 January 25, 2011 06:52
exact solution of acoustic equations pran Main CFD Forum 0 February 14, 2002 02:46
Exact 2D NS solution for benchmarking? Tony Main CFD Forum 4 July 31, 2001 14:50
