tube-in-tube
Old   June 4, 2003, 11:01
Default tube-in-tube
Andrew
Hi all, im brand new to CFD. Im trying to model a tube-in-tube heat exchanger using fluent 6.1. The tube is very long and then with fully turbulent flow. Can anyone give some insight as to what kind of turbulent model, mesh and wall treatment to use?
thanks alot Andrew
Old   June 4, 2003, 11:23
Default Re: tube-in-tube
Dayton
Do you want to simulate heat transfer too and also conjugate heat transfer.
Old   June 4, 2003, 12:59
Andrew
yes. one tube has air entering at 400k and the other, air at 1300k
Old   June 4, 2003, 14:53
Dayton
In case of conjugate heat transfer ..., remember never to use k-epsilon turbulence model, it overpredicts the heat transfer. As you are using Fluent, you can specify velocity directly as inlet condition, outlet you can specify as pressure-outlet. As far as turbulence intensity and length scale are concerned you can use corelations given in Varstegee and Malansekara (hope I have spelled it correctly) for pipe turbulent length scale. I hope with this you can solve your problem.
Regards
Apurva
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
What is best mesh for cylinder tube? olivia FLUENT 7 January 16, 2014 05:55
Tube inside a tube simulation Rashmichem Main CFD Forum 0 December 14, 2010 01:52
BC at the inlet of a tube Jackie Main CFD Forum 11 July 29, 2003 11:57
Draft tube and MFR/SG nyatoto CFX 0 June 3, 2003 05:55
