May 28, 2003, 06:34 |
CFD Code in MATLAB
I am in search of any CFD code written in Matlab/C++ or VB. it is for the design of combustion chamber.
please help if you can thanking you |
June 13, 2003, 11:04 |
Re: CFD Code in MATLAB
I woulnīt dare to run a CFD Code in Matlab. Matlab is very slow for such an application. If you use a combustion chamber (turbulent flow) you need some thousand grid points (depending on your geometry). If you use a chemistry model ( quite simple one) then your computer will slow down. If you start a transient calculation using a fine grid and a sophisticted chemistry model, you will get your results after some months. I mean try to calculate a real problem for an existing application, not a dummy problem.
Try to write a simple 2d program for a simple heat conductivity calculation. Then simply increase the number of grid points. Now think that a CFD calculation needs much more time to converge than a simple heat problem. If you donīt believe me try your own calculation. You will regret it! best regards Jannis |
the best CFD code for women | For the marketers | Main CFD Forum | 17 | August 24, 2006 12:17 |
A simple CFD code for teaching basic CFD? | Christoph Lund | Main CFD Forum | 13 | September 14, 2005 04:36 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
CFD JOBS and Expected Salary.... | Noel Harrison | Main CFD Forum | 11 | November 22, 2000 07:15 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
