Please help! (incompressible navier-stokes)
Hi, i'm getting unconvincing flow reading from my solar tower model. The tower's air exit velocity is in the order of 10^5 when i'm expecting below 100m/s. I can't find where the source of the problem is, as all other aspects (the visualization and temperature distribution) are making sense.
Any of you has this kind of problem before, please comment on this thread. thx! |
If i understand well what a solar tower is(*), there could be a problem with the incompressible flow assumption. In fact you are not simulating a simple adiabathic flow but a very complex one in which different effects contribute to the divergence of the velocity field as the heating from the external source, the vertical size on which the motion takes place and the expected exit velocity which is at the upper limit of the incompressible approximation. All these things put together could well made the flow be far from the incompressible case.
Obviously i assume that everything else is fine, like the grid, boundary conditions, proper dimensions, etc. (*) For solar tower i mean an hollow axialsymmetric building, a very tall one, in which the air, heated at the base by the solar heat, flows through the top exit where some kind of turbine (probably not present in your simulation) is placed. Is this right? |
you are absolutely correct about how my solar tower model looks like. And it's a simple 2D model, which i initially hoped could give better results than in 3D, but turns out not :(
I've checked the boundary conditions, buoyancy formula and input correct air properties value as well as using Lagrange quadratic in the subdomain setting. couldn't find where's wrong. If you don't mind, I wish you could do me a favor by checking the boundaries again :P |
Actually, if you are using the RANS approach, the correct model is the axialsymmetric one (Fluent has this kind of model) and there is no reason to switch to a 3D model.
I don't actually understand what you mean for "checking the boundaries" but, considering that everything seems fine (even if you MUST switch to the axialsymmetric model, the 2D approach it's not unreasonable and usually just gives you wrong results with the same order of magnitude of the right ones), i think that you need to switch to the compressible solver for the reasons that i stated before. |
the boundary conditions are the elements that i specified before solving the model. for example no-slip conditions at the wall and convective flux at the tower's air exit. anyway, i might wanna try out your suggested solution to switch to compressible solver, which i currently use incompressible (i just assumed it's incompressible cuz the 100metre-high tower wont make much difference in the air compressibility property)
Thanks sbaffini |
What numerical method do you employ ? What BC do you apply ? Which solver do you employ ? Does it include RANS modeling? A solution of the order of 10^5 suggests that your solution has exploded. Check the implementation of your boundary conditions. If you employed central differencing switch to upwind and see if it works.
Hey guys thanks for the many help! harishg, i'm using the lagrange quadratic method and linear solver. the inflow is not fixed too as this is what i wanted to find. Up until now,i did not realize there's a mistake in my navier stokes equation. I was suppose to input a formula written as Fy = beta*gravity*density*volume*(T-293)
where beta = coefficient of heat expansion of air T = temperature however since my model is 2D, i wasnt aware of the volume cuz i do not have z-axis!!! i never thought of this before, until i decided to check the equation again...sigh..anyone who can tell me how do i input a volume into a 2-D model? |
I suppose, you can replace volume by area for two-dimensions... I assume that the volume you have in your expression is the volume of your solar tower..
Hi there's one more thing that's making me gone crazy at the moment. I suspect that the X and Y coordinates in FEMLAB are not exactly showing the SI dimension (metre) which I believe is the reason why i'm getting blown-up velocity value. For instance, I drew my model at 800metre long, (i followed the '800' on the x-axis), the resulting velocity output is beyond supersonic! then i changed the length to 8metre, then velocity becomes 30m/s, which is way making more sense.
I suspect that the 'number' at both the axes are factored or scaled-up representation, but I could not find anywhere in the help files that could verify this. FEMLAB only claim that the dimension is in SI units by default, but there must be something wrong with the axes dimension. Help anyone? thanks |
yes sbaffini, the dimension is the main problem right now, but the problem is, i dont know what unit does the scale means. there are only numbers, so i can't be sure if '10' means '10 meters' and there's no way for me to find out. Things are not gonna change even though i draw the model in scale, but the results depends on the scale factor that FEMLAB has here. So what i need now is to verify the scale factor of the dimensions and hopefully, using that to scale down the blown-up velocity results.
