-   Main CFD Forum (https://www.cfd-online.com/Forums/main/)
-   -   Two phase flow (https://www.cfd-online.com/Forums/main/63070-two-phase-flow.html)
Benzaa March 27, 2009 10:13
Two phase flow
I am working on modelling a two phase flow; one is solid and the other is a gas.
I have a doubt regarding the continuity equation for the gas. I hope you can help me to get around this.
In my model, solid and gas are reacting, while solid is falling due to gravity. The mass generated by the gas-solid reactions is transfered to the gas.
The continuity equation for a gas is: D(rho)/Dt = 0.
But, I am wondering, if for my problem, I have to add another term that represents the total mass that is added to the gas flow. I am thinking that it should look something like this:
D(rho)/Dt = R
Where R is the sum of all the mass generated by the gas-solid reaction.
By using this equation, the SIMPLE algorithm changes a little bit.
Is it ok to do this, or, should I just consider the first equation.
Thanks is advance for your help.
CFDtoy March 27, 2009 18:21
Two-phase flow
Hi Benzaa,
If the mass of gas is increasing or decreasing - or solid mass is dec or increasing...you would require a source term on the volume fraction eqn. If you are simply solving a eulerian gas phase eqn and a lagrangian tracker
for the solid phase, no rhs term exist.
CFDtoy
Originally Posted by Benzaa (Post 211060)
D(rho)/Dt = R
