Gas Dynamic Problem
Old   May 5, 2009, 06:41
Default Gas Dynamic Problem
afifi
afifi is on a distinguished road
Dear All,
Do anyone here have experienced dealing with gas dynamic problems using CFD?
Fyi, currently i'm doing some research using 'dynamic boundary conditions' for solving one of my test cases..
The objectives are to find the mass flow rate and time taken;
1. case 1: storage tank, there is a leak, gas coming out.. constant volume, what is the mass flow rate?
parameters: Cd, pressure, density, area of leakage, lamda..
2. case 2: pipe.. continous flow.. there is a leak.. how is the gas flow rate with continous varying volume.. same parameters as above..
3. case 3: storage tank and pipe flow in and out of the tank.. there is a leak.. what is the mass flow rate? same parameters as above..
I have done with case 1.. success..
Any suggestion, which method and approach should i use for case study 2 and 3? What equation and formulas?
Thank you in advance for all the help
cheers!!
afifi
afifi is offline   Reply With Quote
Problem with Dynamic Mesh and Fluent Claude FLUENT 0 December 12, 2006 06:14
Sod shock tube problem with real gas effects ganesh Main CFD Forum 0 October 17, 2006 01:22
problem about dynamic mesh of VOF model whpsoft FLUENT 0 September 8, 2005 23:06
Divergence in Dynamic Mesh Problem James FLUENT 0 September 28, 2004 08:43
Flow-Response Dynamic Coupled problem wavefront FLUENT 2 September 28, 2001 11:33
