Unit vector in 3-D
Old   August 18, 2003, 05:16
Default Unit vector in 3-D
beggin
Hi, how many projections (2 or 3) it is necessary to define an unit vector in 3-D space? Three projections (ax, ay, az) it is obviously enough. But since ax^2 +ay^2+ az^2=1 it is may be enough two values? Thnx.
Old   August 18, 2003, 05:40
Default Re: Unit vector in 3-D
versi
only 2 on spherical surface (\theta, \phi).
Old   August 18, 2003, 06:09
Mario
ax^2 +ay^2+ az^2=1 is enought to determine the absolute value of 3rd component only. the direction must be specified additionally.
so, you need all 3 components in 3D
Old   August 18, 2003, 07:00
beggin
Thank you, but why on sphere enough two numbers (latitude and longitude)? My be spherical coordinates give "more information" than the cartesian coordinates? I always considered that they are equivalent.
Old   August 18, 2003, 08:07
Kevin
You need two points to define a vector. In 3D, you need the 3 coordinates of both points, i.e. x1,y1,z1 and x2,y2,z2. In your case, point 1 is at the axes origin and the norm of your vector is 1. Only two more informations are to be provided :
- two angles, in cylindrical coordinates, the norm being known
- two of the cartesian coordinates, the last one being detremined by the norm relation (x2**2 +y2**2+z2**2 = 1).
Unit normal vector of nearest wall l_r_mcglashan OpenFOAM Programming & Development 3 May 13, 2014 17:06
UDF unit and FLUENT output saifulraju FLUENT 4 September 21, 2010 22:22
Unit for a source term JP CFX 4 July 14, 2005 14:29
how to search unit lenson Siemens 1 April 28, 2005 03:35
unit of fluent yinyue FLUENT 0 November 3, 2004 08:57
