May 19, 2009, 23:19 |
A problem about initialization
zhangyuan
Rep Power: 16 |
Hi,everyone
I need your help, I have a problem in modeling the steady gasification of coal water slurry. The inlet pressure of the oxidizer is 8.1Mpa, and the mass flow rate of the oxdizer is 15.72kg/s, and the velocity is 55m/s. But if the velocity is defined as the boundary condition of the inlet and initialized, the mass flow rate of the oxidizer is 129kg/s in the result of my simulation, more than 15.72kg/s. And if the mass flow rate is defined as the boundary condition of the inlet and initialized, the velocity of the oxideser is 2.88kg/s, less than 55m/s. I want to know why? I try it again and again, but get the same result. Can anyone help me? Thank you! |
May 20, 2009, 01:17 |
N/A
Rep Power: 17 |
I do not have much knowledge about multiphase flows but seems you have some problems with the specific model that you employ for your computations to obtain such a vast difference in the predictions. Where do you get your parameters from ? Also are you sure you the models that you employ has shown to produce good results for the gasification studies ?
May 20, 2009, 03:26 |
#3 | |
zhangyuan
Rep Power: 16 |
I read many articles about simulation of the gasifier of the coal water slurry, and they are similar with what I am doing. So I use the same models as them. Non-premixed combustion model is used to simulate the chemical reactions and DPM model is used to simulate the paticle phase in my simulation. I am sure of them. The parameters what I am using in my simulation are from the industry. |
Initialization problem when using Axisymmetry BC | Eduardo | FLUENT | 0 | August 4, 2008 09:23 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
coal combustion initialization problem | Chetan Prahsant | CFX | 1 | May 1, 2007 05:41 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
