August 25, 2003, 07:41 |
Fluent residual problem?
I have problem in which I chose to take residual to be continuity 1.0e-06 x-veloc 1.0e-06 y-veloc 1.0e-06. But after running for more than 3000 iteration my solution is not converged. although my residual value for x and y velocity is leass than 1.0e-06. I want to know what should be the next step for me. Please help
August 25, 2003, 10:19 |
Re: Fluent residual problem?
Firstly, I would suggest that you post on the specific Fluent forum, as you may get code specific help there. However, if I understand your question although I am not sure I do, it is not wise to monitor convergence based just on the level of your residual, you should check other parameters in your solution. You have not really given enough information for anybody to be more specific, I would suggest doing so in the Fluent forum.
Andy |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 10:54 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 07:11 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
