Rayleigh Number
Old   March 26, 1999, 08:13
Default Rayleigh Number
Thomas P. Abraham
Hello Everyone:
I was trying to get a good definition of Rayleigh number and its physical significance.
I understand that Rayleigh number gives the dominance of free convection. If the Rayleigh number is high, the turbulent effects are dominant too. I was told that if the Rayleigh number is more than 1.0e+07, turbulent effects need to be accounted. Am I right about this?
I am trying to check out some basic text books. Unfortunately, all these text boks are checked from the library. I need to wait tiil they are returned.
Till then, all your comments are appreciated,
Thomas
Old   March 26, 1999, 09:58
Default Re: Rayleigh Number
Heinz Wilkening
The Raylaigh number kann be calculated as:
Ra = Re*Re*Ar*Pr
Re: Reynolds number
Ar: Arcimendes number
Pr: Prandtl number
It is a seminarity number for the natural convective heat transfer. It includes efects of turbulence, buoyancy and heattransfer.
You may calculate it as
Ra = g*rho*l*l*l*(T-T0)*cp/(mu*lambda)
You may think of a flow in a 2D box/room one side wall high temperature over side low temperature. Top and bottom adiabatic.
For such asituation the flow in the boundary layer along the sidefwall will become turbulent if Ra>10^7, as you mentioned.
Ciao Heinz
Old   March 26, 1999, 10:25
Thomas P. Abraham
Hi Heinz,
Thanks for your nice definition. It was well defined.
I never heard of Arcimedes number. How is that defined? It seems to give the strength of buoyancy.
Thanks,
Thomas
Old   March 26, 1999, 10:49
Heinz Wilkening
the Archimedes Number should be something like the ratio of the strength of the buoyancy to the strength of inertia on a fluid partricle, as you mentioned.
You can calculate it like:
Ar = g*beta*l*(T-T0)/(U*U)
See also the posting by Erich: Isobaric compressibility of Air
Ciao Heinz
Old   March 27, 1999, 06:39
Thomas P. Abraham
Hi Heinz,
Thanks for your definitions.
Thanks,
Thomas
Old   November 13, 2017, 01:55
Vignesh Lakshmanan
ViLaks is on a distinguished road
Sorry for starting the thread again, I need to know the significance of Ra.
For my natural convection problem, my Ra is around 129120.
In this case, I wanted to know if the heat transfer occurs due to Conduction or conduction and convection. It is mentioned in wikipedia that when the Rayleigh number is below a critical value for that fluid, heat transfer is primarily in the form of conduction; when it exceeds the critical value, heat transfer is primarily in the form of convection. But what is that critical value?? My working fluid here is air
Thanks
Vignesh
ViLaks is offline   Reply With Quote
Old   November 13, 2017, 03:16
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks
Vignesh
To understand the role, just see where the Ra number enters into the equations. It is a measure of the relevance of the term it multiplies.
FMDenaro is offline   Reply With Quote
Old   November 13, 2017, 03:23
Vignesh Lakshmanan
Dear Filippo Maria Denaro,
Thanks for your reply. But, Im sorry, how could I check that?
With Regards
Vignesh
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
