initial and boundary conditions for flapping hovering flight |
April 12, 2010, 10:57 |
TWB
Rep Power: 19 |
I'm thinking of doing some simulations of hovering flight. in the past, i've been doing simulations of flapping flight. i simply set u=1,v=0 as the initial condition for the entire domain. the boundary condition is u=1 at the left boundary, indicating inflow. outflow at the right uses convective boundary condition. du/dy=0 for the top/bottom boundary. however, how should the boundary and initial conditions since it's hovering. hence, u/=1. pls help. tks! |
April 12, 2010, 23:10 |
As the name suggests -- hovering flight -- there is no forward motion, you can use initial conditions u = v = 0 everywhere. Its just the same flapping motion of the wing in still fluid. As for the boundary conditions, use u = 0 for inlet and the same outlet B.C you have mentioned. Dominic |
August 30, 2012, 11:22 |
TWB
Rep Power: 19 |
I currently used symmetry BC, although I believe convective outlet should work fine too.
August 30, 2012, 13:11 |
#5 | |
saeid oqaz
Rep Power: 14 |
other B.C you used seem correct except outlet. why you use symmetry BC for outlet? |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
