FLUENT, flow past a circular cylinder
Old   March 23, 1999, 20:09
Default FLUENT, flow past a circular cylinder
Paul Reichl
I am looking at flow past a cylinder (in 2D) using Fluent 4.4.8, and I am finding that I am unable to get the correct shedding frequency (which I am measuring, by considering the changes in velocity observed at a monitoring point situated in the wake). While I am getting shedding, which has the correct spatial wavelength (ie. the distance between the successive waves on a streamline plot looks to be about 5 cylinder diameters) and the flow field looks correct, the period of vortex shedding reported via the monitoring point is much to large (by a factor of between 4 and 5). At first I thought it was a scaling problem, but using the same grid (built using geomesh) with FLUENT UNS, gives the correct period and hence Strouhal number. I have discussed this with another user of Fluent, and when he compared some of his results for a completely different problem with those of other researchers, he found that his results had to be evolved for 5 times as many time units in order to obtain a similar result. So essentially I am asking if anybody has either experienced this problem, or has any ideas as to what is wrong.
Old   March 24, 1999, 07:42
Default Re: FLUENT, flow past a circular cylinder
WEI
Could you tell me the Re-number in the simulation?
Old   March 24, 1999, 09:57
John C. Chien
(1). change the numerical scheme, check the input, run another case, (2). change the inlet condition slightly, say 1%, check the input, run another case, (3). change the mesh density only slightly, check the input, run another case, (4). if you are running a turbulent flow case, change the turbulence model, check the input, run another case. If all the solutions are about the same, then, the code is consistent. ( you can trust it) If you think FLUENT UNS is better, then use it. If you still have problem, then ask the support engineer to supply you a complete set of the input for the flow over a 2-D cylinder to see whether you can "duplicate" it. ALLWAYS CHECK OUT THE BLACK BOX USING A TEST CASE TO SEE WHETHER YOU CAN "DEPLICATE" THE RESULT AGAINST THE DEVELOPER'S RESULTS, BEFORE YOU EVEN START RUNNING YOUR OWN PROBLEMS. (A BLACK BOX IS A BLACK BOX! NEXT TIME WHEN YOU RUN THE CODE MAKE SURE TO DIVIDE THE PERIOD BY A NUMBER BETWEEN 4 TO 5. THIS WILL SOLVE YOUR PROBLEM. ASSUMING THAT THE RESULTS ARE REPEATABLE AT ANY TIME.)
Old   March 24, 1999, 11:16
andy
The distance between successive wakes divided by your "freestream" velocity will give the approximate time period. If the value you calculate by other means differs greatly then you can be sure where the error lies! Almost any prediction will produce a reasonable result for the shedding frequency so long as vortices are shed. The frequency is fairly insensitive to numerical/modelling errors but the magnitude is another matter. The only other suggestion I can think of is to look for a missing pi (i.e. what are the units for your frequency?).
Old   March 24, 1999, 11:57
Patrick Godon
Hi Paul, There is some literature about the formation of secondary frequencies in the wake of a circular cylinder with vortex shedding. The main point is that when boundary conditions are imposed on the variables (rather than on the characteristics of the flow) then the boundary becomes (partially) reflective and this (resonnance) phenomenon can induce additional frequencies in the flow. The main reference to this is: Abarbanel, Don, Gottlieb, Rudy and Towsend, J. Fluid MEch., vol.225, p.557. So this might be another direction to look for the difference in frequencies. Cheers. Patrick.
Old   March 24, 1999, 16:28
Paul Reichl
For those that asked the Reynolds number being considered is 400 (Based on diameter).
Old   March 24, 1999, 16:58
Paul Reichl
Thanks for the suggestions, I have tried changing the scheme, but get the same results. I have tried using different grids but again the same thing happens. I am looking at flow for a Reynolds number of 400, so I am not using any turbulence model. I would use FLUENT UNS, but I want to look at free surface flows, and FLUENT UNS can't model them. I will try modifying the inlet boundary condition and see what happens.
Thank,
Paul
Old   March 24, 1999, 17:24
John C. Chien
There is one thing you can check, that is, run a steady-state solution on both codes at a lower Reynolds number ( at a Reynolds number where you are sure that the steady -state solutions exist) and check the results to see whether you are getting the same steady-state solutions. (you are doing fine. It's like detective work. It's fun.)
Old   March 24, 1999, 17:25
Paul Reichl
Thanks for your comments, when I divide the the distance between the the vortices by the free stream velocity I do get the correct period. That is what I was suggesting when I mentioned that the distance between the successive waves on a streamline plot looks to be about 5 cylinder diameters, and since the free stream velocity is 1.0, the diameter is 1.0 and the Reynolds number is 400, the Strouhal number should be roughly 0.2, so the period should be 5 . It tends to suggest that perhaps there is either something wrong with my use of the monitoring point, or something wrong with the time reported by fluent in the time history file.
Old   March 24, 1999, 17:28
Paul Reichl
Thanks, I will check it out.
Old   December 8, 2012, 04:52
Question flow over two side by side cylinder... with Re100 & 200
  #11
rishitosh's Avatar
Rishitosh Ranjan
rishitosh is on a distinguished road
hiii..
i m also new in dis CFD area...
i m working on flow over two side by side cylinders... @ Re= 100 and 200..
i got good results..
but i want to find out Strouhal number for all cases...
i came to know by finding shedding frequency with help of FFT, using cofficient of lift data, in fluent 13.0 we can calculate Strouhal number...
but i m getting helpess..
how to use FFT to find shedding frequency....?????
-Rishi
rishitosh is offline   Reply With Quote
Old   December 8, 2012, 06:18
cfdnewbie
cfdnewbie is on a distinguished road
do a temporal FFT of the vertical / orthogonal to inflow and cylinder axis force. that will give you the Strouhal number
cfdnewbie is offline   Reply With Quote
Old   December 8, 2012, 09:29
Question flow past circular cylinder..
  #13
rishitosh's Avatar
Rishitosh Ranjan
hiii cfdnewbie....
thnx for response..
but i dont know hw to do temporal FFT of the vertical / orthogonal to inflow and cylinder axis force.. ???
can u guide me plz... ???
-rishi
Old   December 8, 2012, 09:46
cfdnewbie
record the force component over time, sample a sufficiently high number of cycles and the do the fft to find the dominant frequency! what is still unclear?
Old   December 8, 2012, 11:54
  #15
rishitosh's Avatar
Rishitosh Ranjan
hii cfdnewbie...
thnx again 4 showing interest...
i hv recorded Cl (coefficient of lift) over time for high no of cycles (60 cycles) in xy file format..
den.... i m following dis step... record>plot>FFT and here i m loading dis file...
den checking FFT...
is it correct way..??? i m not getting desired result..
-Rishi
Old   December 8, 2012, 12:58
cfdnewbie
Originally Posted by rishitosh View Post
hii cfdnewbie...
den checking FFT...
-Rishi
Just load the file in Matlab and do the FFT there (or on octave). Or just plot it over time and determine the frequency by eye. Should be very easy to do, and exact enough to check your result.
Old   December 8, 2012, 15:21
Default flow past circular cylinder..
  #17
rishitosh's Avatar
Rishitosh Ranjan
hiii.
thnx again..
yes, i hv done just by seeing the plot..
Strouhal number(St) comes approx 0.2 for all cases..
but i hv to give precise value of St for all d cases to validate my results...
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Flow past a circular cylinder mesh Turbulent Main CFD Forum 8 December 9, 2012 04:19
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
3D Flow over a circular cylinder Srinivas FLUENT 3 March 15, 2005 19:57
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 10:51
