MI & Higher-Order Convective Scheme.
Old   September 22, 2003, 05:01
Default MI & Higher-Order Convective Scheme.
Ana
Hi everybody.
I am trying to write my own CFD code like a previous phase in my Ph D work. I am using a collocated grid and I am applying the Momentum Interpolation technique (Rhie and Chow) to avoid pressure oscillations.
In all papers that I have read about this approach a linear interpolation is used for the Momentum Interpolation. I think it will work properly with CDS (or Upwind) convective scheme. However, I am not sure about it when higher-order schemes are used: Will it reduce the order of the approximation of the convective velocity?
Could anybody guide me about this subject, i.e., momentum interpolation and higher-order convective schemes?
Thanks in advance, Ana
High order scheme vs Specified Blend factor 1 realanony87 CFX 1 November 10, 2015 10:36
Second order scheme with buoyantSimpleFoam mighelone OpenFOAM Running, Solving & CFD 2 September 26, 2012 10:28
CFL condition for higher order schemes Shyam Main CFD Forum 2 February 14, 2008 14:24
Turbulence quantities solved by 1st order scheme? Damien CFX 3 May 29, 2007 07:54
second order FD upwind scheme Heinz Wilkening Main CFD Forum 2 November 3, 1998 14:33
