July 2, 2009, 15:58 |
coding
Mohammad
Do somebody know about coding in collocated grid? I wan't to know which option is more proper: 1) storing the variable density and viscosity, when they vary. 2) calculating them when they are required. there is a material in the fluid that changes fluid's density and viscosity. this change is due to the concentration of this material. thanks. |
July 4, 2009, 02:13 |
Mohammad Reza Hadian
it depends on your code. how many times do you need these variables.
in my code the eddy viscosity was needed in different parts and i stored them. if you need the variables only one time, maybe it is better not to store them. if you need them in different part (mometum equations, pressure equation and subroutine for printing output) you should store them. |
July 6, 2009, 10:53 |
thanks for your answer
Mohammad
Dear Hadian,
Yes, I think you are right. I have already stored them. I need the density and viscosity many times. Thanks again, Mohammad. |
Help with coding | James | Main CFD Forum | 2 | May 18, 2005 06:12 |
Coding | begineer of cfd | Main CFD Forum | 1 | July 21, 2004 06:11 |
Ground coding enquiry | Wenqing Zhang | Phoenics | 2 | August 12, 2002 12:56 |
total pressure without ground coding? | Vinod Venugopalan | Phoenics | 1 | May 28, 2002 01:25 |
User coding on NT w2k | Philip Jones | Siemens | 0 | November 26, 2001 04:43 |
