backward-facing step flow(turbulent)
Old   October 10, 2003, 17:08
Default backward-facing step flow(turbulent)
A.M.Memarzadegan
I am to Validate my code by solving backward-facing step flow(turbulent). i used kim et al stepflow.I found the problem so dependent to grid generation.when i change the grid of corner of step i obtain different reattachment point. I Wonder if anybody knows a good grid for backward-facing step flow.
the inlet length is 4*step height the inlet dia=2*step height and the total length is 28*step height the inlet velocity is uniform while k & eps prescribed .Re=69610
the k-eps model with wall function has been used.
Kind Regrads,
A.M.Memarzadegan
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Backward facing step. Fluids Main CFD Forum 7 December 4, 2012 11:28
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
