Solidworks, inside volume
Old   August 7, 2009, 21:40
Cool Solidworks, inside volume
AdidaKK's Avatar
Mauricio Caamaño Flores
AdidaKK is on a distinguished road
Send a message via MSN to AdidaKK
Hello everyone ,i have a littel question, im working with Solidworks in a can combustor modeler,and i want to know if exist some tool to generate the inside volume of my model? because for modeling in cfd code its necessary the inside volume wich its where the fluids go and not the structure, so i have ready all the structure but i need the inside volumen.
anyone knows?
thanks very much
AdidaKK is offline   Reply With Quote
Old   August 8, 2009, 08:10
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I usually create a box that covers the whole flow domain of interest. Then, read in the solid part (I do not have SolidWorks on this laptop, but, I think it is "insert", then select part). Do a combine (but, select subtract). If your solid parts is not clean, then, you might get errors. But, most of the cases, you should be fine. So, try this using a simple model first.
I believe that, there is a software called, SpaceClaim, it can do invert of a part or an assembly. I have not used this feature myself yet.
If you need details, let me know. I can write a more detailed procedure.
Good Luck!
Pei
phsieh2005 is offline   Reply With Quote
Old   August 8, 2009, 12:00
Default SpaceClaim
Blake Courter
bcourter is on a distinguished road
SpaceClaim does indeed have a volume extract capability, as well as many other features to help prepare and simplify models for analysis. www.spaceclaim.com. We would be happy to show you how it works on your model. For more information, contact sales@spaceclaim.com.
-Blake
(a founder of SpaceClaim)
bcourter is offline   Reply With Quote
Old   August 10, 2009, 02:18
AdidaKK's Avatar
thanks very very much for you help phsieh2005 im gona do it XD,if some doubt appears can i ask you?
thanks bcourter im gona see your website.
regards
Old   August 10, 2009, 07:53
Pei-Ying Hsieh
Try it using a simple geometry first. Let me know if you have any question.
Pei
regards
Old   August 11, 2009, 22:54
Talking
AdidaKK's Avatar
hey phsieh2005 i have another question about solidworks(im new) and it is possible to do a "combine" in the assambly ? i have 3 solid bodies ,but i want to combine them to get just 1 solid bodie (for mesh situation).
when i get in the assambly i didnt see the combine option, how can i get this?
thanks very much
Old   August 12, 2009, 14:53
Pei-Ying Hsieh
No, you cannot do combine or subtract in assembly mode.
In assembly mode, save the assembly as part (save as, then save as type Part).
Create a box that will cover your flow domain. Then, insert part, insert Feature, select Combine, then select Subtract.
Pei
Old   August 12, 2009, 15:37
AdidaKK's Avatar
thanks very muchs ,that works for me.
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
