What is negative pressure meaning for a head?
Old   March 27, 1999, 19:25
Default What is negative pressure meaning for a head?
Dong Li
I am doing some research for the head using in drive. Appreciated if somebody can explain how the negative presusure generate. Thanks in advance.
Old   March 27, 1999, 21:10
Default Re: What is negative pressure meaning for a head?
Allan Morrison
To me your question is unclear - so I will try to answer what I think your question is. I will assume this is a very basic question about the units used to measure pressure.
1 ATM pressure = 101.3 kpa = 14.7 psi = 10.33 m of water etc. It is common in civil engineering to describe pressure in terms of equivalent height if water pressure as "head" pressure. Therefore a civil engineer could describe one atmospheric pressure as 10.33 meters of water. If the pressure is less than one atmosphere then the pressure is said to be negative (or a vacuum = the amount the pressure is BELOW atmospheric pressure). The units used are the same as those to measure the pressure above atmosphere so it can be said that a pressure that is negative 0.1 atmosphere = negative 1.033 meters of water pressure or a vacuum of +1.033 meters. Hope this is the answer you wanted. Otherwise please repost with more details.
Allan
Physical meaning of pressure in pressure eqn dontknow Main CFD Forum 2 August 30, 2010 10:12
negative static pressure at inlet nino FLUENT 7 July 27, 2007 08:22
negative static pressure Selo melo FLUENT 5 December 18, 2006 09:30
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
