January 20, 2016, 11:30 |
Concentric pipe geometry
Ritesh
Rep Power: 12 |
Hello Everyone,
Actually i am trying for a simple geometry of a concentric pipe flow. In which both the pipes are drawn in same plane. Inner pipe is smaller one with respect to height and dia. as compare to bigger surrounding one. Here I am trying with inlet at face of the small pipe and outlet at the face of the bigger pipe and remaining portion as wall. For this geometry flow is returning inside the small tube, and tip of the inside tube working as wall boundary condition. Whereas if we draw a single pipe, one can able see the flow going out from the outlet this is missing in this case. I need help for this problem, where this inside pipe outlet wall has to be set as interface so flow will distribute through the tip of the small pipe to the bigger pipe. (To get an idea about geometry i have attached images of the geometry.) Kindly give me some suggestions to solve this issue. Thanks. image (1).jpg image.jpg |
blockMesh for a pipe Tee geometry | akluj | OpenFOAM | 3 | February 3, 2021 20:55 |
[Other] Creating a suction hole in a pipe geometry. | Daneish | OpenFOAM Meshing & Mesh Conversion | 2 | August 21, 2015 05:04 |
complete pipe geometry using mirrorMesh | megacrout | OpenFOAM | 0 | June 7, 2011 10:39 |
[Salome] Salome Geometry question (Pipe with certain wall thickness) | Hectux | OpenFOAM Meshing & Mesh Conversion | 1 | April 8, 2009 06:44 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
