Particle break up
Old   October 6, 2009, 16:05
Default Particle break up
eers
eers is on a distinguished road
Hello everyone
I have a model to atomize the fuel at the outlet holes( there are 18 holes on periphery)due to rotation(only) and i can't choose other particle break up models (like pressure atomization, orifice atomization). For a trial i chose water instead of fuel and hav run the vof multiphase (air-primary & water-2ndary) by keeping the BC's as
Wall-rotation (rpm is given)
Inlet-Velocity inlet
Outlet-Pressure outlet
Volume fraction of water at the inlet as 10%
and Back flow fraction- zero
I am not sure weather there'll b reversed flow though i am observing it. I can only see a film at the outlet but not particle break up. If you can understand the problem please give your suggestions if you could as i hav my deadlines coming..
sincerely, thanks in advance
regards
eers
eers is offline   Reply With Quote
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle tracking - Domain interface / FrozenRotor mohanrao CFX 4 January 23, 2008 03:39
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Particle track files Sankalp CFX 1 August 25, 2004 23:25
Particle Trajectory calculation when particle hit yueroo FLUENT 2 February 28, 2001 04:26
