Home > Forums > Software User Forums > COMSOL
buoyancy flow and mass transport
Old   October 14, 2009, 06:01
Default buoyancy flow and mass transport
Michael Rembe
rembe is on a distinguished road
I'm new in this forum and I hope I get some hints helping me to understand my problem. first of all, sorry for my bad english, I'm german.
Using Comsol I simulate brine flow in salt caverns (50... 130m diameter, 50 .. 100m height). It is a laminar up to turbulent flow. At the surrounded wall there is salt dissolution. Salt disssolution causes a higher density of the fluid (rho=f(c,T)), so that mainly buoyancy flow is there. Of course, there is a fresh water input over a well and a brine extraction by a well, too. But the flow (about 10 ... 50 m³/h) is small andit isn't able to control flow regime.
I use FEM (Comsol 3.5a) for solving navier-stokes-eq. and the convection-diffusion-eq. There are many options to solve and tricks to get a solution, but there are some main problems I want to rule.
Buoyancy flow is considered by the Boussinesq-Appr. Fz=-g*delta_rho but it seems, that it isn't very numerical stable. I know there are limitation, delta_rho is about 1300-1000=300kg/m³.
Is there any better way to consider buoyancy flow? This seems to be the main problem.
Other problems are mass transport with a cell-peclet-number >10 ... >100, flow with a cell reynolds-number about 100.
Actual I use a laminar stationary solution, decreasing viscosity and diffusion step by step (restarting) and increasing g of the Boussinesq-Appr. Limit is the number of DOFs to solve for 3D! I use a DELL T7400 with 2 x QuadCore and 32GB RAM.
Is there anybody who works nearly on the same task?
Thank you for any answer!
Michael
rembe is offline   Reply With Quote
buoyancy flow, mass transport
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
