Filtering Prob. for LES
Old   December 5, 2003, 14:19
Default Filtering Prob. for LES
colopolo
I just set up the three-dimensional NS for cavity flow
these days, I'm modifying the code to LES code.
I have no idea where I put the filtering subroutine in my code. the algorithm of code is like this (looks like same as TEACH algorithm)
call init l l start time l l call solve for u,v,w,p l l call solve viscosity l l check time and steady condition
----- like this.. I want to use smagorinsky model at viscosity subroutine
if I use like this one, where do I put the filter subroutine in?
Please give me some ideas
Old   December 12, 2003, 11:54
Default Re: Filtering Prob. for LES
Tim
The finite volume formulation acts as an implicit filter. If you are happy using implicit filter then don't bother with a filtering subroutine as you dont need it. If you use a filter then call it between the velocity solution and the viscosity calculation.
Good luck.
Tim.
implicit filtering student2 Main CFD Forum 0 February 10, 2011 00:10
question about spatial filtering Feng Main CFD Forum 0 June 1, 2010 20:54
LES (explicit) filtering John Main CFD Forum 2 July 29, 2004 18:03
Channel LES and explicit filtering Luca Liberti Main CFD Forum 0 January 17, 1999 10:07
