October 6, 2009, 06:56 |
SIMPLE algorithm-Please help
Thiyagarajan dhayalan
Rep Power: 16 |
hi,
i tried to write a code for SIMPLE algorithm in Fortran but found it difficult. can anyone give a sample code on SIMPLE.my mail id is rajandhayalan@gmail.com thank you regards Thiyaga. |
October 6, 2009, 09:56 |
zobekenobe
Rep Power: 17 |
are you writing it with colocated grids and staggered grids
October 7, 2009, 03:05 |
Simple
Rep Power: 16 |
hi,
thanks for the reply.iam using staggered grid. reg Thiyaga. |
October 8, 2009, 06:08 |
have u tried veersteeg's book, coz the algorithm in it is almost the code. I have implimented it in mathematica.
October 9, 2009, 01:46 |
Rep Power: 16 |
hi,
thx , i will try... |
October 17, 2009, 11:01 |
jk
Rep Power: 16 |
Hi Ammar,
I tried with verteeg's book only. But the solution is blowing out (simple algorithm). Please check whether my following boundary conditions are correct: firstof all i am using staggered grid (backward) and using Explicit scheme. Assume it is a duct flow --> two walls on the upper and lower side (v velocity = 0), leftside --> inlet (u velocity) and rightside -->outlet (pressure outlet) but the u velocity grid would be the last on the right side I have just created a dummy nodes outside the main domain (as mentioned in the book). my domain size is 0.09m by 0.09m, height 0.08m. Grid size is 20 by 20 1. On the inlet i am giving u velocity = 0.1 m/s 2. On the outlet i am extrapolating this u velocity as given in the book 3. On the top and bottom wall my v velocity = 0 4. on the right side (just before the u node -- outlet) i am fixing the pressure as 0 I have doubt in the pressure correction (pprime) bc. 1. On all the sides i am setting the value of pprime = 0. Withall this my solution is blowing out after few iterations (5 iterations) Also for the simplicity i am keeping the value of meu and row as constant in all the equations (common row(density) taking out from the equations and canceling). I am not doing any averaging on this scalars. If you wish i can send my code also (its fully commented) Your suggestion is highly appreciable. thanks jyo Last edited by jyothishkumar; October 17, 2009 at 11:35. |
October 17, 2009, 17:52 |
#7 | |
Rep Power: 17 |
Dear friend. you should tell more details about your problem. your geometry.boundary conditions and...
maybe I can help you Quote:
October 17, 2009, 18:15 |
#8 | |
Rep Power: 17 |
what are the values of under-relaxation for velocity and pressure?
you should set the pprime value zero at the beginning of each iteration. for B.cs usually the outlet boundary is difficult to set. Quote:
October 18, 2009, 00:56 |
pprime initialisation
#9 |
jk
Rep Power: 16 |
Hi Artmiss,
I did the initialization of pprime. My urf for u and v, pressure is 0.3. for the outlet boundary since i am giving the pressure outlet (0 value -- gauge) my pprime would be zero at the outlet as there are no corrections my u and v velocities are going very high values and finally diverges. any suggestions thanks jyo |
October 18, 2009, 07:58 |
#10 | |
Rep Power: 16 |
Dear jyo,
Put The relaxation factor for U and V around 0.3-0.4 and for Pressure around 0.1. You should notice that relaxation factor for pressure should be less than for U and V ones. The other thing is before you wanna call your pressure boundary and solver you should put pprime=0.0 in the main Do of your program. hope it will work. Quote:
October 18, 2009, 15:25 |
#11 | |
Rep Power: 17 |
Dear friend. perform the suggestions of Mr. babak.The SIMPLE algorithm is very sensitive to urf's especially when Re increased.Don't use the values suggested in commercial soft wares. I doubt the reality of convergence with this urf's!
for final check tell me the method of calculation of u and v at solid boundaries.it is important Quote:
October 19, 2009, 04:15 |
#12 |
jk
Rep Power: 16 |
Thanks and i will do that
October 21, 2009, 08:40 |
#13 |
jk
Rep Power: 16 |
Again i have restructured my grid pattern in the following manner. I am now giving pressure inlet and pressure outlet boundary. Even on the wall (top and bottom) also i have my pressure and u velocity grid to coincide. This way i am sure about the pprime values at the boundary. Now my pprime value on the left and right side (inlet and exit) boundary will be zero. On the wall i am doing pwall = p(i,1) = 2*p(i,2) - p(i,3), similarly i am doing for pprime also. One more thing that i want to clarify is that i am fixing the value of row and meu everywhere (in the scalar grid points). Is that fine what i am doing. (still on the process of writing the code) Any suggestions ? thanks jyo |
simple |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
SIMPLE algorithm | jika | Main CFD Forum | 2 | October 22, 2009 06:46 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | Main CFD Forum | 0 | April 18, 2007 03:48 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | FLUENT | 0 | April 13, 2007 23:17 |
SIMPLE algorithm | Jonathan Castro | Main CFD Forum | 3 | December 10, 1999 04:59 |
