Home > Forums > Software User Forums > COMSOL
steam flow in a pipe driven by a pressure gradient between inlet and outlet
Old   March 11, 2010, 06:52
Default steam flow in a pipe driven by a pressure gradient between inlet and outlet
Salvatore Catalano
SalvoCalvo is on a distinguished road
Hi All,
i'm a new user of Comsol 3.5. In this moment i'm experiencing some problems of convergence to solve a steam flow in a pipe of 4.75 mm.
The flow is driven by a gradient pressure between the inlet and the outlet:
- inlet 500 kPa
- outlet 100 kPa (approx. atmospheric pressure)
I'm using the chemical engineering module>flow with variable density>non-isothermal flow>k-w turbulence model>steady state analysis because i'm interested on looking into also the temperature in the pipe as the steam's temperature at the inlet is 121°C.
I set as initial condition of temperature for the gas domain 298K. I used the material library of comsol to set the properties of the steam (there is exactly steam in it).
Boundary condition for the turbulent weakly compressible flow model are
-inlet: pressure> no viscous stress 500 kPa (default settings k0 turbulent kinetic energy 0.005 m^2/s^2 and w0 specific turbulent dissipation rate 10 1/s)
-outlet: pressure> no viscous stress 100kPa
-walls of the pipe: wall> logarithmic wall function (default setting deltaw=h/2)
Boundary condition for the convection and conduction model are:
-inlet: 394,15 K
-outlet: convective flux
-walls of the pipe: -1 W/m^2
The simulation does not converge. I've tried in different way...also with a lower pressure as 150 kPa doesn't converge! It converges only deactivating turbulence model and setting as inlet condition a low velocity inflow i.e. 0.1 m/s.
Does anybody know how to do? Maybe k0, w0, h/2 for the wall setting are wrong? To be honest I don't know how to set them.
Thanks in advance for anybody could support me!
Salvo
SalvoCalvo is offline   Reply With Quote
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 07:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
