meshing with flawed CAD geometry
Old   January 27, 2004, 01:31
Default meshing with flawed CAD geometry
kevin buhra
How can I make mesh with a CAD geometry which has lots gaps/cracks. Spent lots of time fixing the geometry. It's very difficult to find the intersection of the sufraces. But I do not want the model changed. Is there any meshing software available.
Thanks.
Kevin
Old   January 27, 2004, 04:02
Default Re: meshing with flawed CAD geometry
burakreis
you have to use a cartesian mesher such as harpoon from ensight or viscart from cfdrc or cart3d etc...
Old   January 27, 2004, 08:58
ag
What meshing software are you using? One trick that we use quite often in Gridgen is to create surface patch meshes that span the gaps, write those out as plot3d meshes, and then read them back in as part of the database. It can be somewhat tedious, but that's the real world of mesh generation.
Old   January 28, 2004, 01:31
deLuther
ICEM CFD can help in such situation.
[ICEM] Geometry Tolerance and meshing Mitpostdoc ANSYS Meshing & Geometry 4 January 1, 2012 12:51
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 11:15
Need help on meshing this simple geometry nha1g08 ANSYS Meshing & Geometry 3 March 9, 2011 02:13
Meshing the geometry Vidya Raja FLUENT 0 February 26, 2006 19:44
Meshing Film cooling geometry Janendra Telisinghe CFX 1 January 31, 2006 06:16
