September 1, 2022, 10:45 |
Doublet influence matrix vortex panel method
L.
Rep Power: 3 |
In "Katz & Plotkin: Low speed aerodynamics" the idea of the equivalence between a constant doublet panel and a vortex ring panel is discussed and proved. This allows the evaluation of the effect of doublet by means of a closed vortex ring which is an easier expression if you ask me.
However, and I have seen it in multiple papers/books, on 356 of K&P it is stressed that , where is the entry of the doublet influence matrix. That is, the effect of a unit strength doublet of panel j on the normal velocity at collocation point of panel j is a half. This does not make sense in my opinion. Suppose we have a square panel with it's collocation point at [0,0,0]. Then, if we double the size of each vertex, the distance from each vertex (or vortex line) is increased and its influence is reduced. I have attached a very simple python (in .txt) code which basically mimics the VORRING subroutine (eq 10.117, K&P) and if you play with the numbers it is simply confirmed that the influence on its own collocation point is not 0.5. For sources however this seems to be the case. To that extend, are there any basic sanity checks to see whether or not the source/doublet influence matrices are constructed correctly? And do you agree with my point? Last edited by lWiNdY; September 1, 2022 at 10:46. Reason: weird attachment appeared |
September 5, 2022, 10:16 |
L.
Rep Power: 3 |
I was mistaken; The velocity POTENTIAL influence matrix has this property. Not the velocity influence matrix!! Therefore, the question is irrelevant and the thread can be considered closed.
influence matrix, panel method |
Advice on coupled panel method | jancellor | Main CFD Forum | 0 | October 6, 2018 12:20 |
singularity distribution about panel method | rogerliu | Main CFD Forum | 2 | February 5, 2013 12:30 |
does vortex panel method satisfy no-penetration boundary condition? | rogerliu | Main CFD Forum | 1 | December 3, 2012 04:40 |
Problem building 3D Panel Method | Daniel | Main CFD Forum | 0 | September 15, 2006 07:51 |
calculating missle configuration by panel method | Daniel | Main CFD Forum | 5 | January 6, 2003 08:09 |
