March 4, 2004, 06:13 |
ICEM Tetra
Hi all,
I have a question concerning ICEM Tetra. Is it possible to mesh a volume with an inserted baffle? If so, could you please tell me how this can be done? thx |
March 5, 2004, 02:16 |
Re: ICEM Tetra
ICEM Tetra automatically creates triangular shells on all surfaces, so if only your geometry model contains internal surfaces, you should get the baffles automatically in your mesh.
March 5, 2004, 03:41 |
Re: ICEM Tetra
No this is not the case. I have a room with a baffle inside and when I have a look at the mesh no triangles are created for the interior surface (zero thickness). I guess tetra can't do it, because nothing is mention in the manual about zero thickness surfaces in volumes.
March 5, 2004, 06:01 |
Re: ICEM Tetra
You have to enable "internal wall" in Geometry->Mesh Params->Select Family. If neccessary you can split the evolving shell elements into two (if you have to distinguish left and right side) in the mesh editor
March 5, 2004, 16:46 |
Re: ICEM Tetra
Thank you for your help
ICEM Tetra mesh, Size reduction and Skewness problem | Catthan | ANSYS Meshing & Geometry | 6 | December 5, 2010 19:39 |
Exporting ICEM Tetra Grid to Fluent with Hexa-Core | Tim | FLUENT | 2 | August 30, 2007 07:16 |
Exporting ICEM Tetra Grid to Fluent with Hexa-Core | Tim | Main CFD Forum | 4 | August 28, 2007 04:05 |
Icem tetra - Running in parrallel? | Joe | CFX | 5 | September 9, 2006 12:37 |
ICEM CFD 5.1 problem with tetra count | Baskaran | CFX | 2 | March 13, 2006 12:59 |
