Implementation of the Low-Reynolds-number Chien model
Old   March 24, 2010, 18:16
Question Implementation of the Low-Reynolds-number Chien model
Marco
om3ro is on a distinguished road
I'm trying to implement the Chien model with OpenFoam, but I have some general doubts on the description of y+.
The Chien model uses y+ for the definition of the damping factors.
Suppose to describe a 2D duct flow in with the following configuration:
HTML Code:
<pre>
     /\  y
      ------------>  x
____________________________________________
->_________            _ ,    °   .________,*________->
                  |____ _|  |___ __|
</pre>
y+ is defined as: y+ = (U_t * y) / nu
and U_t(x) = sqrt(tau_w(x) / rho)
y+, U_t, tau_w are functions of x!!!
It is necessary to define for each point (x,y) of the numerical domain the x coordinate in which define y+, U_t and tau_w.
An example:
In both points identified with " * ", tau_w must be evaluated in " , ".
But in the point " ° ", shall tau_w be associated with " , " or with " . " ?
Does anybody have experience on this aspect? What is the principle to adopt in this task?
Marco
om3ro is offline   Reply With Quote
chien, low-re, openfoam, yplus
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
low reynolds number K-epsilon model amar FLUENT 25 October 7, 2015 14:07
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
How low for low Reynolds model? Jean-Luc Phoenics 3 March 10, 2001 01:34
