Why is my fluent simulation giving Cp values above 1??? |
March 24, 2010, 15:01 |
hello to everyone on the forum Im a newbie!! can anyone help??
I have recently carried out some fluent simulations of an aerofoil in a wind tunnel. details; 2D steady flow simulation standard k-epsilon turbulence model with standard wall functions pressure correction technique simple algorithm disecretisation pressure, second order momentum, second order upwind turbulent kinetic energy, first order upwind turbulent dissipation rate, first order upwind inlet is a pressure inlet, outlet right hand wall is pressure outlet zero gauge pressure. aerofoil is given wall boundary conditions. the simulation agrees with experimental results when the aerofoil is set at zero incidence but with higher incidences around 10 degrees the Cp value goes above 1 which cannot be correct... Does anyone have any idea why this is occuring?? thanks |
March 24, 2010, 15:23 |
Rep Power: 18 |
Are you sure you're not computing -Cp?
March 24, 2010, 15:40 |
well I was computing Cp values over the aerofoils top and bottom surfaces using the static pressures that the simulation gave, for comparisson to the Cp values calculated from experimental results.
So really I am asking why would the simulation find static pressures at the leading edge of the aerofoil that are greater than the inlet pressure (total pressure)??? |
March 26, 2010, 09:12 |
Hi
Dynampally Pavitran
Rep Power: 16 |
The Cp values can be more than 1 for compressible flows.
1. I guess the flow in your simulation is incompressible. Take correct inlet velocity(V) value, for computing Free stream Dynamic Pressure(0.5*density*V^2). |
IC engine simulation tutorial by FLUENT | yash | FLUENT | 4 | April 6, 2015 19:44 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
IC engine simulation tutorial by FLUENT | yash | Main CFD Forum | 1 | April 21, 2009 05:05 |
Fluent simulation over airships | Aragon | FLUENT | 8 | March 30, 2009 12:12 |
Getting values from fluent solver | Moshiur R. Chowdhury | FLUENT | 2 | November 27, 2002 13:41 |
