2D Airfoil modeling using Spalart Allmaras Model |
April 15, 2010, 04:54 |
Mahbub Islam
I am trying to find lift and drag coefficient of NACA2412 airfoil using Spalart Allmaras (S-A) Model for Reynolds number 10^6. But the solution is not converging and calculated Cd and Cl values are far from actual one. I have checked y+ value in between 1~28.
Can anyone suggest me about improving convergence criteria for S-A model? or Any reading material related to using S-A model in fluent? Is there any special tricks on meshing? or How I can modify mesh in fluent to improve convergence? Thank you in advance. Waiting for reply. |
April 15, 2010, 10:42 |
Rep Power: 19 |
y+ from 1 to 28 means your grid is bad. For Spalart Allmaras you need to keep your y+ less then 1 OR larger then 100. Using a grid with y+ from 1 to 100 will give you a bad solution.
Do |
April 15, 2010, 11:49 |
Mahbub Islam
Thank you DoHander.
Can you suggest me any procedure by which I can reduce y+ closer to 1. I will be highly grateful for this help. |
April 15, 2010, 13:51 |
Rep Power: 19 |
You can estimate the height of the first row of cells at the wall imposing an y+ of say 100 and providing the Mach and Reynolds numbers for your case. You have an y+ calculator here in cfd-online from which you can estimate what is the minimum cell height at the wall.
Do |
April 15, 2010, 23:08 |
Mahbub Islam
Thank you DoHander. I have tried with the calculator to calculate the cell height. Not yet successful.
Probably I have to take more care about mesh formation. If you have any 2D airfoil mesh you may share with me. That will be a great help. |
April 15, 2010, 23:14 |
Mahbub Islam
naca2412, spalart allmaras, turbulence, turbulence model |
reference values - 2D airfoil model | ANDRES ORTIZ | FLUENT | 6 | April 1, 2015 18:33 |
Spalart and Allmaras Paper | Mohamed | Main CFD Forum | 7 | July 10, 2014 16:39 |
Numerical integration of Spalart Allmaras turbulence model | RenardP | Main CFD Forum | 0 | June 11, 2009 14:53 |
Spalart Allmaras Turbulence model - Need article! | CFD Student | Main CFD Forum | 0 | December 27, 2004 04:28 |
Time Step Size for Airfoil Model - Fluent | Prateek | Main CFD Forum | 0 | November 4, 2004 18:42 |
