How to generate equations/formula for any airfoil |
April 18, 2010, 11:17 |
TWB
Rep Power: 19 |
I understand that for NACA00xx airfoils, there's a formula which can output the y coordinate given the x coordinate. However, if I need a similar formula for a general airfoil whereby I know x/y coordinates, how can it be done? Any recommendation? Thanks alot! |
April 18, 2010, 16:21 |
Rep Power: 19 |
If your points are well behaved (no errors in the data) you can always use an interpolation function to obtain formulas for the upper side and the lower side of your airfoil. After all you can easily fit a polynomial function on a given set of points.
If using interpolation won't give you a nice surface (this will be the case for non accurate data) you can always use a least square approximation with orthogonal polynomials (e.g. Chebyshev) to obtain an analytical formula for your airfoil. Do |
April 19, 2010, 00:15 |
TWB
Rep Power: 19 |
Thanks DoHander.
In fact, the airfoil I'm interested in is the s1020 airfoil, as shown over here: Currently I have a total of 60 points for this airfoil. Based on your experience, which mtd do you think it's better to get a good fit? Is it possible to use the 30pts for the top and bottom airfoil with the least square approximation? Thanks again! |
April 19, 2010, 10:52 |
Rep Power: 19 |
Yes, I think you can use the least square methods with 30 points. Probably you can use Matlab to solve the problem, if I remember correctly it has a least square fit, not sure however if Matlab use simple polynomials or orthogonal polynomials.
In the past I've used a C# code to solve the problem, but any programming language you know will work. Do |
April 19, 2010, 12:14 |
Rep Power: 16 |
If you download some software such as designfoil you can make most airfoils i think. You can also export these to CAD software as well.
April 19, 2010, 19:01 |
Rep Power: 17 |
EDIT: Nevermind ...
Low Speed Airfoil | Mancusi | FLUENT | 7 | April 3, 2014 06:11 |
How to generate the geometry of a muti-element airfoil? | peaksun | Main CFD Forum | 0 | November 4, 2009 07:00 |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 11:31 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
How to generate structured tandem airfoil mesh? | CH | Main CFD Forum | 3 | September 19, 2006 14:59 |
