MPI combine data
Old   April 26, 2010, 21:54
Default MPI combine data
Pham Anh Hung
tanphong is on a distinguished road
Send a message via Yahoo to tanphong
Dear all!
I am beginner for parallel computing with MPI for fortran.
The data has been received for different Processes, the combination of all data need for the post-process.
So, how should I do to combine data from all different processes?
Thanks in advance!
tanphong is offline   Reply With Quote
Old   May 17, 2010, 17:46
Default Collective Communication
Hans Bihs
valgrinda is on a distinguished road
Hei,
use MPI_GATHER, then all processes send data to the the root process. At the root process you can then assemble the data in the correct order and write out a solution file.
Note that this requires a lot of communication, especially if you have large data files. Maybe you can use a post-process tool that can deal with parallel output instead, like Paraview for example. That would be the most efficient solution.
Cheers
Hans
valgrinda is offline   Reply With Quote
Old   May 19, 2010, 05:07
Nicholas F Camus
Killercam is on a distinguished road
Hei,
You could also write a serial code to collect all the bits of the parralell data in a single array. Then write that array to file. Simples.
Cheers,
NFC
Killercam is offline   Reply With Quote
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Transfer data in MPI hall Main CFD Forum 0 May 3, 2004 18:57
