6DOF duration
Like Tree1Likes
  • 1 Post By agd
Old   April 20, 2022, 04:18
Default 6DOF duration
Chehade
Chehade is on a distinguished road
Hello, how long do yall think an 11M cell 6DOF simulation would take? Using 8 processors, 16GB ram and 1 solver GPU. I understand there is no way to find exact duration but as approximation how long do yall believe? (Simulation is that of Wind Turbine turning due to air)
Thanks.
Chehade is offline   Reply With Quote
Old   April 21, 2022, 08:58
agd
agd is on a distinguished road
Well, about <------------this long----------->
Seriously, without any information about which solver, solver options, processor type, or anything else the question is meaningless. But if you know the solver you might check and see if anyone has provided average statistics on solver efficiency (check published papers for things like avg time per iteration per cell). Then figure that your timestep will need to be small enough to resolve the cycle time of the wind turbine (which will be a function of the angular velocity of the turbine) and that you will need to run enough steps to get rid of initial transients and get a good result - say 5 rotor revolutions. Then put all that information in a blender and calculate your number.
aero_head likes this.
agd is offline   Reply With Quote
Old   April 21, 2022, 09:38
Chehade
I understand. Thank you for the insight, hopefully it wont take as long as expected. Also i have posted a new thread called "Wind Blade Serration Method Error" if you could kindly check and give your thoughts.
why fluent 6dof rotational mass cannot be changed?? EngGhost FLUENT 7 January 31, 2023 23:40
Modelling Contact and Frictional Force in 6DOF wcj1n18 Fluent UDF and Scheme Programming 2 March 12, 2021 04:17
Buoyancy and the 6DOF solver (FLUENT) i2a FLUENT 16 March 20, 2020 11:20
6DOF for spring valve motion problem ahehuhehuh Fluent UDF and Scheme Programming 2 April 18, 2018 15:39
Fluent 6DOF TETRA Multibody benjamin_ FLUENT 0 November 12, 2013 04:50
