April 21, 2004, 12:47 |
transient pressure correction
hi,
i'm doing pseudo-compressibility pressure correction in transient low R_e flow in a tube (2D). how do I choose optimal ratio between dt for velocity update and (pseudo) dt for pressure correction? in particular: is it better to do more velocity corrections and few pressure corrections or vice versa? thank you. |
April 22, 2004, 07:51 |
Re: transient pressure correction
If you are using pseudo-compressibility method, then pressure is also updated via time or pseudo time marching, then you do the same times of corrections to both V and P.
April 22, 2004, 17:03 |
you mean, correct velocity, correct pressure and again, in a loop? yes, that is clear, but what about "dt", how do I set optimal relation between two delta t's for both explicit time marching...?
thanks domi |
April 23, 2004, 05:29 |
Years Ago AIAA Journal had papers discussing pseudo time sep and physical time step. The pseuodtime step has the meaning of relaxation factor, it can be larger than a nondimensional physical Dt. may be 10 times up, I remebered. If the inner iteration is implicit can be 10^12 up. (== discarding it at all)
April 23, 2004, 11:14 |
read paper on dual time step approch , try one by Yoon and Jameson on LU-SSOR for eular and NS eqn and there are some more by Jameson that explains dual time stepping approch quite well.
May 27, 2004, 08:03 |
Harlow & Amsden
Hello everyone,
Is there anybody who are using IMF(Implicit Multifield Model of Harlow & Amsden) technique for their studies?I want to ask some questions. thanks |
Pressure correction equation,Ferziger and Peric | Hooman | Main CFD Forum | 1 | July 20, 2010 05:21 |
Pressure correction on SIMPLE | Diego Nogueira | Main CFD Forum | 6 | October 10, 2004 14:43 |
Transient pressure in conduit | John | Main CFD Forum | 0 | October 28, 2003 17:26 |
Pressure correction question - Please help! | Barry | Main CFD Forum | 1 | February 5, 2003 00:27 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
