May 22, 2004, 15:44 |
heat equation solution source code
Hi all,
I look for a source code in C++ or Matalb which solves the time dependent 2-D heat conduction equation in a square section for a given BC and IC using finite difference method and finite volume method. I prefer a code which uses SOR and Crank-Nicolson scheme. Anyone has a idea where can I find examples or related source codes ? Thanks in advance, John |
May 27, 2004, 23:41 |
Re: heat equation solution source code
Hi john,
I have written a code for this 2-d heat conduction equation(unsteady)using ftcs scheme. I have written the code in "VISUAL BASIC". Will this be helpful for u? bye jyo |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
best source code for energy equation solving | negar | Main CFD Forum | 1 | August 14, 2008 04:31 |
open source code for conjugate heat transfer? | cchou | Main CFD Forum | 0 | December 7, 2006 19:26 |
variable heat source simulation | LI Y | FLUENT | 1 | April 7, 2003 23:46 |
