June 1, 2004, 12:38 |
Explicit Pressure Based Scheme
Hi
Till now what ever pressure based scheme I have read are implicit, are there any explicit pressure based scheme. Thanks Apurva |
June 1, 2004, 12:52 |
Re: Explicit Pressure Based Scheme
Really ?
if you read Versteeg's book, it tells you what is the explicit scheme on page 171, and then the Crank-Nicolson scheme and the fully implicit scheme on the subsequent papges. Li |
June 2, 2004, 21:52 |
So how do you couple the pressure-velocity in case of an incompressible fluid? Do you use the old pressure field to calculate the new velocity field and then adjust the pressure field afterwards? Best Regards |
June 3, 2004, 04:47 |
Correct. You can read Versteeg's book. In page 142, it states that an initial pressure field is guessed....
Regards Li |
June 3, 2004, 20:01 |
SIMPLE alghorithm p.142.
Ok since my maths aren't my strongpoint I might be wrong here, but doesn't that make the calculation quite implicit (i.e. you dont't use all known values to calculate for instance x-velocity component in a node at a higher time-level)? |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
Pressure vs. Density based | jan | FLUENT | 2 | May 3, 2007 03:45 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Pressure based and Density based Solver | Xobile | Siemens | 1 | November 30, 2004 21:13 |
