December 24, 2010, 18:13 |
Internal CFD on a surface model (SW2010)
Rep Power: 15 |
Im attempting to do an internal CFD simulation on a surface modeled exhaust manifold. I have drawn the complete manifold however i am unsure on how to run an internal CFD simualtion on a surface model. If anyone could let me now how its done i will be most gratefull. Im happy to email the surface model if it helps. I will attach an image also
The software that im using is soldiworks 2010 flow simulation. Im fully capable of running CFD on a solid model however applying the same method to a surface model is proving unsucessful. If anyone could advise me on how to complete CFD on a surface model i would be most gratefull. Last edited by sw1990; December 24, 2010 at 19:06. |
December 25, 2010, 08:40 |
Vieri Abolaffio
Rep Power: 16 |
Close your surface, make it a volume and perform your analysis on it.
December 26, 2010, 17:09 |
Rep Power: 15 |
thanks for the advice sail, however i need advice in terms of step by step solidworks comands as im unsure of the procedure for Internal CFD on surface models.
As i am so desperate to find out the method, im willing to screen share on skype with someone who can instruct me on completing the CFD. Im willing to paypal a reward to anyone that can help me sucessfuly preferably over skype screen share. |
December 28, 2010, 11:12 |
Rep Power: 15 |
any further assistance? im realy desperate to find a solution and welcome any further instructions from people with knowledge of solidworks CFD software. Thank you
December 28, 2010, 16:32 |
Nuno Gomes
Rep Power: 16 |
soldiworks 2010 flow you have an adviser who may help you
January 4, 2011, 06:59 |
Mitch
Rep Power: 15 |
Signed up just to help you as i have an interest in making exhausts on these packages :P
Mate im not sure about surfaces but all the hollow solids i have done as i have also done exhausts, you need to make caps. SW advisor has a walkthrough in the help for internal flow. Essentially u need to make up a disc that is the same diameter as the ID of your exhaust, you then mate this in the end of the pipe so that the disc is flush with the outside. Now i cant rememeber if your flow will originate from the outter circle of the disc not the inside face or not so just play around with that. If you use the floworks advisor or tutorial thing it will actually run you through this process, it will have a 'create lid' or something.. good luck |
January 4, 2011, 10:17 |
Rep Power: 15 |
cheers for the advice. The method that you have mentioned is what i have curently been using whilst modeling an inlet manifold. This method has proved successfull.
However today i have spoken with a tutor who has a lot of CFD expeirence and he explained to me that you canot do an internal CFD on a surface model using solidworks as it hass zero thickness that the mesh cannot compute. Therefore the tutor who actualy set me this assignment has set a task that is impossible! therefore i shall be meeting with him tomorow to get his verdict |
January 4, 2011, 19:36 |
Mitch
Rep Power: 15 |
Hehe thought there may be problems with doing it as a solid, i normally use a 3d sketch and a sweep i think
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
Mapping results from CFD grid to structural grid of a free-form surface | mbecker | OpenFOAM Running, Solving & CFD | 1 | October 18, 2013 10:16 |
Validation of surface roughness model approaching a hydraulically smooth surface | jola | CFX | 1 | October 20, 2010 10:06 |
About Brackbill's Continuum Surface Force (CSF) model | James | Main CFD Forum | 4 | August 23, 2010 06:09 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
