periodic boundary condition in rectangular duct
Like Tree1Likes
  • 1 Post By nedanikou
Old   November 6, 2016, 11:11
Default periodic boundary condition in rectangular duct
Neda S. R. Nikou
nedanikou is on a distinguished road
Hi All,
I have written a 3D Incompressible NS solver for solving a rectangular duct flow with periodic boundary conditions along the direction of flow (xi). I wrote periodic boundary as follow
Uxi(1:ne,1:nz,1)=Uxi(1:ne,1:nz,nk-2)
Uxi(1:ne,1:nz,nk)=Uxi(1:ne,1:nz,3)
Ueta(1:nei,1:nz,1)=Ueta(1:nei,1:nz,nki)
Ueta(1:nei,1:nz,nk)=Ueta(1:nei,1:nz,2)
Uzeta(1:ne,1:nzi,1)=Uzeta(1:ne,1:nzi,nk-1)
Uzeta(1:ne,1:nzi,nk)=Uzeta(1:ne,1:nzi,2)
P(P(1:ne,1:nz,nk)=P(1:ne,1:nzi,2)
P(1:ne,1:nz,1)=P(1:ne,1:nz,nki)
xi, eta and zeta are the curvilinear coordinate directions. Initial condition is fully developed laminar velocity profile.
Width, height and length of duct is 1m, 1m and 15m, respectively. First I used coarse grid generation (xi=1:100, eta=1:10, zeta=1:10) with relaxation factor of 0.1, results were so close to fully developed laminar flow. Then I used finer grid (xi=1:150, eta=1:20, zeta=1:20) with relaxation factor of 0.01 results were so close to fully developed laminar flow. As I generated finest mesh(xi=1:200, eta=1:40, zeta=1:40), residuals of velocity and continuity started to oscillate. It did not diverge but I am not sure of convergence yet. Is it reasonable to have oscillation in solution domain and then I get reasonble result?
I want to do grid convergence test with different sizes of mesh.
Would you Please help me... What is wrong?
nedanikou is offline   Reply With Quote
Old   November 6, 2016, 11:45
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
You did not specify your integration method, is it explicit? How do you check for the stability constraint? How do you compute the residuals?
FMDenaro is offline   Reply With Quote
Old   November 6, 2016, 12:06
Neda S. R. Nikou
Dear FMDenaro
I useduse power-law scheme for momentum equation, which is implicit and SIMPLE for velocity-pressure coupling.
Old   November 6, 2016, 12:14
what about the Reynolds number? what about the spatial discretization?
Old   November 6, 2016, 12:21
Neda S. R. Nikou
Reynolds no. is 500 and finite volume method was used for discretization.
Old   November 6, 2016, 12:32
your problem is not totally clear... is the Reynolds computed using u_tau? In such a case you get a turbulent flow...
do you check your code for a smaller Re number (=O(1)) and the exact laminar solution?
Old   November 6, 2016, 12:41
Neda S. R. Nikou
thanks to your answer.
yes, I checked the code for the duct with 116 m length. I tried to use periodic B.C. to decrease running time. This would be only simple study case to check some of the RANS and LES models, but honestly it was the difficult part of coding. Is it possible to decrease the relaxation factor to smaller values like 0.0001? or it is unnecessary.
Old   November 6, 2016, 13:09
RANS is a steady formulation, LES is time-dependent, they are very different and the code (space and time integration methods are very different) ...
Could you post the convergence error slope you get at low Re number?
What residuals are you controlling? Did you see oscillations in the velocities field? Are you using variable grid near the walls?
Old   November 6, 2016, 13:36
Neda S. R. Nikou
I should check the slope variation, it will take time to run my code again.
residual of uxi, ueta, uzeta and continuity
resuxi=resuxi+dabs(Usxi(j,k,i)-Uxi(j,k,i))
resueta=resueta+dabs(Useta(j,k,i)-Ueta(j,k,i))
resuzeta=resuzeta+dabs(Uszeta(j,k,i)-Uzeta(j,k,i)
for the coarse and moderate grid, there was no oscillation in velocity field the after convergence of velocities field.
thanks to your help
Old   November 6, 2016, 13:49
Actually, the residuals of the momentum equations should be the discrete time derivatives so that you control that the solution is steady. Oscillations appear in the continuity residual?
However, try also to diminuish your convergence thresholds on the finest grid.
Could you post the velocity plot superimposed to the exact solutions?
Old   November 6, 2016, 15:17
Default fully developed laminar flow
  #11
Neda S. R. Nikou
fully developed velocity profile and residuals attached please find it.
File Type: pdf fully developed laminar flow of rectangular duct.pdf (20.6 KB, 9 views)
Old   November 6, 2016, 15:30
I see that the profile has a not vanishing values at y=0 and is not symmetric with regards to the centerline... also the analytical solution is wrong, has two values at y=0. How do you compute the analytical solution?
As you have a 3D duct, you must check both the profile u(y) and u(z). Is the profile along x the same?
Old   November 6, 2016, 15:42
Neda S. R. Nikou
the analytical formula was calculated based on fully developed laminar formula of velocity from White's book. there is no value at the first and end of velocity formula, I write it myself by mistake. this is a correct formula and symmetric just shifted.
uxi is constant along the duct as it is expected.
velocity residuals shows decreasing slope but continuity increases at the first iterations and then decreases
thanks
Old   November 6, 2016, 15:56
thanks
I don't remember that White illustrates the analytical expression for rectangular duct ... I remember the solution for pipe and parallel plates.
Are you sure the solution you use satisfies the equation Lap u = Re* dp/dx with u=0 on the rectangular section?
Furthermore, have you checked that inflow and outflow flow rates are exactly the same?
Old   November 6, 2016, 16:23
Default viscous fluid flow of White pge 119-fully developed laminar flow
  #15
Neda S. R. Nikou
viscous fluid flow of White pge 119. pic of formula attached. I am sure about mass inflow and outflow. let me check the residual plot for fine grid.
Old   November 6, 2016, 17:00
yes, depending on the numbers of harmonics you satisfy the equation...you should check if your oscillations depend on the used thresholds.
Old   November 6, 2016, 17:06
Neda S. R. Nikou
yes, depending on the numbers of harmonics you satisfy the equation...you should check if your oscillation depend on the used thresholds.
thank you for your patience and valuable guides
FMDenaro likes this.
Old   November 6, 2016, 17:27
I suggest also to provide the analytical solution as initial field, check if you get the convergence using a low threshold.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
About periodic boundary condition. kohel_11 FLUENT 3 July 30, 2013 08:37
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
