How to handle FORTRAN Error?
Old   June 23, 2004, 13:48
Default How to handle FORTRAN Error?
CFD Student
Dear CFD people, I am trying to validate my laminar 2d finite volume -ROE FDS- solver using NACA0012. However, as I increased the number of grid point, I met the following error and couldn't fixed it. Can you please help me? Thanks. Regards.
Error I met:
forrtl: severe (170): Program Exception - stack overflow
Old   June 23, 2004, 14:49
Default Re: How to handle FORTRAN Error?
agg
Try to create a 64 bit object file so as to increase the memory allocation for arrays. I use the -64 compiler option for f77 on an SGI machine.
Old   June 23, 2004, 18:32
Jarmo Monttinen
See the following discussion: http://www.cfd-online.com/Forum/main.cgi?read=31685
-- Jarmo
Old   June 24, 2004, 08:04
Steve
A stack overflow usually indicates that you have huge local arrays in a function or subroutine.
Try declaring your arrays as DATA or COMMON. This will take them off the stack.
Old   June 26, 2004, 12:03
CFD student
Thanks a lot for valuable suggestions.
I modified the stack size in the executable itself using EDITBIN, such as: editbin /stack:4000000 main.exe
It worked
Regards.....
Old   June 29, 2004, 16:35
John
I think you did this in linux based system. right?
Is it possible to do in Windows-based fortran compilers like Lahey-Fhjitsu or Digitial Visual Fortran as well?
Thanks,
Old   July 2, 2004, 05:32
CFD Student
I use "Compact Visual Fortran Standart Edition 6.5.0" and Windows XP. Regards.
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
