KIVA simulating on parallel CPUs (64 bit machine) ??
Hi everyone,
Does anyone know, what I need to do in order to run KIVA on few CPUs rather than one? I would be very grateful if you could help me to reduce the simulation time by running on few CPUs. Cheers Nik |
Hi Nik,
First of all I need to know what version of KIVA you are dealing with and also whether that version is a parallel one or you would have to parallelize it by yourself. Regards daniel |
Hi Daniel,
Thanks for your reply, I am using KIVA-3v, which I think needs to be modified first to run it in parallel. Cheers Nik |
Hi Nik,
It's correct, KIVA 3V is a serial distribution of KIVA, so that if you want to run it in parallel you'll have to implement a parallelization in your code by yourself. I can imagine that is not going to be easy at all :( I'm using KIVA 4 which is a parallel distribution, then the parallelization is already implemented in it, so I have no clue about how to do it. Good luck Dani |
