Pade type higher order schemes
Old   July 17, 2010, 14:19
Default Pade type higher order schemes
Ramesh K
RameshK is on a distinguished road
Send a message via Yahoo to RameshK
Hi all
I was developing a code for Compact FVM schemes of order 4. I tried implementing it to linear equations and worked fine all the convection, diffusion and convection diffusion with periodic boundary conditions, but when applied the same scheme for Euler 1D equations the solution is diverging. I found that it was the interpolation at the boundaries that are causing the trouble tried out different possibilities but failed , any suggestions regarding this.
RameshK is offline   Reply With Quote
compilation problem with "fvPatch::lookupPatchField" Ya_Squall2010 OpenFOAM Programming & Development 9 November 15, 2021 22:01
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 15:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Gradient Estimation for Higher Order Schemes jianxia Main CFD Forum 0 June 6, 2000 19:40
