Tangential derivative Cell-Based Finite Volume |
July 15, 2010, 19:56 |
Hi everyone,
I am searching a discretization method for the tangential derivative terms of the viscosity. For example if we have two cells with exact same y coordinate, how do we calculate du/dy? Here dy is the direction tangential to the face. As a solution, someone told me to use the derivative between the vertices of the face. Well, I didn't like this solution. The equation in fact says div(div(V)) where V is the vector . The outer divergence is solved with the Gauss(divergence theorem). But unless there is another method, the inner one should be solved. That's why i am looking for the discretization of du/dy, using cell based method. (only the cell based properties, face normal and tangent vectors, and the distance between cells). Or should I use the solution that I didn't like? Thanks, P.S: div(div(V)) problem exists also for the div(grad(V)). But I assume the solution of one, will also be the solution of the other. Sorry for English, |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
InterDyMfoam gives strange gamme if cell volume changes due to mesh motion | daniels | OpenFOAM Running, Solving & CFD | 8 | April 7, 2009 09:31 |
Finding a more accurate volume for each cell | Rjakk | Siemens | 1 | March 20, 2007 15:46 |
Equations for finite difference, element & volume | W.L.C. | Main CFD Forum | 9 | April 3, 2001 12:08 |
